underthetire
Jan 24 2010, 11:28 AM
QUOTE(nsr-jamie @ Jan 24 2010, 05:44 AM)
QUOTE(RJMII @ Jan 24 2010, 02:35 PM)
Jamie, wow! That's HUGE! What do you make with that?
Yes; we're aiming for the m0-4 chassis. (I think... is that the chassis that the group buy for the bodies was? )
Actually it looks big but is small compared to some of the others we have at work, I use this one the most, mostly mill and machine steel parts used for big progressive dies. I forgot the model name I think something like 50cv or something like that, its actually quite old and we bought it used around 10 years ago or so for 35,000 Dollars roughly. We have 5 other high end Okuma's that are for very detailed work and cost as much as a nice home. The Okuma machines are very easy to use with their OSP systems, none of that Fanuc stuff.
I do like the older OSP controls, the new ones seem complictaed to me with the new panel. MC50VA i'll bet. Still, nothing wrong with a good old reliable Fanuc. I could see why you'd want Okuma, they are built in Nagoya.
RJMII
Jan 26 2010, 01:00 AM
OK, now I need help.
I've found different options for collets to replace the drill chuck. I've got a 3/8 - 16 draw bar.
There are these:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...e=STRK:MEWAX:ITBut how do I 'clamp' with them?
Then there are the ER32 and ER25 MT2 collet holders from Hong Kong:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...e=STRK:MEWAX:IThttp://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...e=STRK:MEWAX:ITalong with the collet sets:
http://cgi.ebay.com/SHARS-PRECISION-ER32-C...=item518cbbf19fWhich is the best way to go? (I'm open to links from other sources, also)
Rleog
Jan 26 2010, 07:36 AM
How about creating an emblem for those with Jake's 2270 engine. A 2.27 seems overdone; maybe a 2.3, or 2.3 - 4
Thanks
Smitty911
Jan 26 2010, 09:20 AM
For testing programs get some "Machineable Wax" It's harder than candle wax and you can re-melt it.
http://www.machinablewax.com/
underthetire
Jan 26 2010, 01:25 PM
QUOTE(RJMII @ Jan 25 2010, 11:00 PM)
There are these:
Ok, ER is a STD collet now days, where a MT (morse taper)2 is not. However, you would need to clamp a ER in a MT2, since that is what your machine is designed for. I would go with MT2 collets for what you are doing. The drawbar just threads in to the back of the collet and sucks it up in to the spindle. The taper on the OD of the collet will "crimp" the cutting tool and hold it very well.
underthetire
Jan 26 2010, 01:27 PM
And, ER32 is too big for what you want. You'd want a smaller ER i think. ER20, or even a 16.
RJMII
Jan 26 2010, 05:21 PM
Great! Thank you. =o) I'm currently the winning bidder for the MT2 collet set (hopefully it stays that way).
That's going off of your recommendations. thank you again.
RJMII
Jan 26 2010, 05:22 PM
QUOTE(Smitty911 @ Jan 26 2010, 08:20 AM)
http://www.machinablewax.com/Thank you!! I will certainly keep that in mind. =o)
underthetire
Jan 26 2010, 05:34 PM
QUOTE(RJMII @ Jan 26 2010, 03:21 PM)
Got some test tools coming my way. I'll pick them up this week.
RJMII
Feb 12 2010, 06:23 PM
My machinist friend here in town has been working on my stepper motor mounts.
I thought I'd add a couple of pictures of it as my path to making the emblems progress.
Shade Tree
Feb 12 2010, 06:55 PM
QUOTE(RJMII @ Feb 12 2010, 04:23 PM)
Hey that there LoveJoy coupler you are using. Do you ruin lots of the rubber inserts by having space between them like that? I use L075's on my gold dredge. If there is ANY space there, I'll eat two rubber inserts per day.
RJMII
Feb 12 2010, 08:26 PM
QUOTE(Shade Tree @ Feb 12 2010, 05:55 PM)
That's a picture of progress of it being built and fitted. It hasn't been run at all with the steppers attached. take a closer look at the pictures and you can see how the mounts are adjustable. The gap for the lovejoys will disappear.
nsr-jamie
Feb 13 2010, 09:42 AM
I have some used but excellent condition 6mm and 8mm roughing and end mills I don't need any more I could let you have...maybe in exchange for a couple of those green Matchbox 914 cars sold in the US now.
RJMII
Feb 13 2010, 10:22 AM
QUOTE(nsr-jamie @ Feb 13 2010, 08:42 AM)
I'll find a couple. PM your address to me.
RJMII
Mar 21 2010, 10:58 PM
Here we go! My mill is now set up with the cnc stuff. My XP box (yellow computer under the Wii) is running the mill and the 3d scanner.
in this picture I'm scanning a wheel that BKLA sent to me. (thank you, for the use of the parts to scan!)
The end mills that underthetire offered showed up as well, and thank you for them, as well. they are certainly appreciated.
The other picture was the first thing that I carved with the mini mill; it's my 5 year old's name. He was all excited that we had the machine set up and was once again begging me to build Wall-E. We carved his name out instead.
(I drink out of canning jars, I make sure to drink a LOT of water)
RJMII
Mar 21 2010, 11:46 PM
oops. dbl post.
RJMII
here is a picture of the scanner screen while it scanned/aligned the first round of scans for the wheel.
this is going to get edited and turned into a Fuchs, then machined out of aluminum. (or plastic, wood, or wax for the first couple runs, to make sure i have the code right)
Dr Evil
Mar 21 2010, 11:47 PM
When are you gonna send me the electronic assembly to build?
RJMII
Mar 21 2010, 11:49 PM
QUOTE(Dr Evil @ Mar 21 2010, 11:47 PM)
mid-april. I have to order some more pieces parts for it and print out the instructions again.
nsr-jamie
Mar 22 2010, 05:50 AM
Hey, I forgot about this post. Good to see you got it going...I still have some end mills for you (in 6 and 8mm) roughing and finishing end mills and also some 3D ball end mills in 4 (2R), 6(3R), 8(4R) and 10(5R) I can let you have, they are used but in excellent shape....I still need those wheels for the RC cars....hint hint
Tom
Mar 22 2010, 09:31 AM
RJM11,
That is so cool! I got a Taig mini-lathe 6 or 7 years ago. Nice to have when you need a custom bushing made, etc. I guess you know a mill can be used like a lathe also? You can go to the TAIG web pages and gets LOTS of info on mini-lathes and mini-mills.
Have fun,
Tom
underthetire
Mar 22 2010, 09:37 AM
Not to make any of you sick, cause I know i was, a guy here bought 3 Hardinge tool room lathes from our company auction for 1500.00! Another guy picked up a small Hurco CNC 3 axis mill for 500 bucks. ( small as in 15X25 travel). Wish I had a garage i owned !
RJMII
Mar 22 2010, 11:17 AM
almost ready to start taking pre-orders.
I'm getting much closer, and am able to carve the 914-8 out of wood.
RJMII
Mar 22 2010, 11:23 AM
@Tom; thanks for the tip! The electronic piece that is going off to Dr Evil is my 4 axis controller.
The wheels will be getting made on the setup you're referring to. i'll look over the Taig site for sure, anything that helps me learn the easy way is a good thing.
@underthetire... sounds like a couple of people scored some really good deals. how often are the company auctions?
underthetire
Mar 22 2010, 11:31 AM
QUOTE(RJMII @ Mar 22 2010, 10:23 AM)
Once a month. I need to get on the list myself. There is some really nice slightly older machines heading over to the recycling center this week through next month.
