I see on the wiring diagram that both seat-belt switches (and their things) get their power from and are grounded by an electronic "Seat-belt warning system relay and integrated buzzer" (J-34 on the diagram).
I don't know that the car won't start since mine was disconnected (read unplugged) when I got the car. but there are only two states... shorted or not. Somebody will know this, but if it were me:
1. take the passenger seat out
2. unplug the switch
3. Turn the ignition on (no starter of course)
If the buzzer buzzes, then short the two wires and make it go out. Should take you 30 minutes with a 10mm rachet.
Good luck!
QUOTE(High Path @ Feb 6 2010, 05:50 AM)
What is the best way to defeat the interlock on a 1974?
How does the interlock function, i.e. what does it prevent from happening to keep the car from running?
