QUOTE(Kargeek @ Mar 8 2010, 11:31 AM)
Click to view attachmentI know things once worked properly since I built this car…Saturday I fire up my car- it’s been since last fall I’ve driven it and I discovered I have no brake lights. I have the lights on- no brake lights. I turn off the lights and I now have brake lights. This I discovered after removing the pedal board and checking the brake light switch, fuses and anything else I can think of.
So, I’m thinking relay, current flow, ground problem or the notorious Porsche Gremlin. Before I whip out my electrical diagrams and squint through electrical current flows- does anyone have any suggestions to look for? DH
Hey "Neighbor" - purdy car!
Recheck your leads for tail-lights & brake -lights to see if you're getting a fault across them, as well as checking in the housing for a fault across. You may also have a weak/semi-corroded connection at one/both brake-light bulbs/sockets that gets overpowered with the tail-lights coming on (my 85 BMW 325e whacks out every so often with turn signals at the rear like that), which can usually be remedied by cleaning with steel wool & Wurth Contact Oil or similar product. Could also be a bad or going-bad relay, if none of those.
Otherwise, since it once worked properly after you built it, chances are that you've developed a short somewhere in the harness/wiring leads - unless you replaced a new harness with the rebuild. The old insulation just gets brittle, cracks then shorts across - which was also typical in old VW's & other imports & domestics of that day.
Where in Orange are you? I'm by OHS on Shaffer! BTW - had mine since 75!
Cheers!
Tom T
