QUOTE(r_towle @ Mar 15 2010, 03:40 PM)
Im not certain that the wipers are part of the headlight circuitry but it would not surprise me. There is alot of stuff going through that headlight switch.
BUT
If you have the intermitent wiper relay....its located under the hood, passenger side cowl support. That may be getting power via the headlight circuit (you said it only runs once) so look for a square relay under the hood and check your wiring.
Rich
Rich not sure if my car has intermitant wipers but it does have a relay but on the drivers side cowl support. Even with this pulled the wipers activate when the headlight switch is activated.
