Socalandy
Mar 16 2010, 02:33 PM
If you had a set of factory GT flares and a real 914-6 car would you flare it?? Remember, My -6 car has no fenders at all right now and the Orig. engine case is not with the car.
smg914
Mar 16 2010, 02:36 PM
QUOTE(Socalandy @ Mar 16 2010, 12:33 PM)
"No, I wouldn't"
tod914
Mar 16 2010, 02:38 PM
Why cut up an original 6? Will be worth more if left alone down the road.
JmuRiz
Mar 16 2010, 02:40 PM
Is the motor stock/numbers matching? If it's a modded car that will influence my vote.
tat2dphreak
Mar 16 2010, 02:43 PM
yes, and this is why... since you have to work on the fenders anyway... IF you like the flares, do it.... I'm not as big on the GT flares as I am custom "smooth" flares... but if you like them, then there's nothing wrong with doing them in this case...
if you had pristine, original flares... I might feel differently...
Mar 16 2010, 02:50 PM
It's your car, your money, your choice.
jhadler
Mar 16 2010, 02:59 PM
I say go for it. It's not a matching numbers car to begin with, and obviously the body of the car needs a lot of help.
Make it how you want it.
-Josh2
dr914@autoatlanta.com
QUOTE(Socalandy @ Mar 16 2010, 01:33 PM)
Maybe one this far gone, but never a nice car.
drgchapman
Mar 16 2010, 03:15 PM
Zundfolge
Mar 16 2010, 03:16 PM
Since its not going to have the original engine ... and you have to basically rebuild the entire car around the VIN plate, I say go for it.
But if it was a clean, daily driver condition 6 I'd say no.
bandjoey
Mar 16 2010, 03:17 PM
yes. If you're going to spend so much getting this body back on the road, move ahead with the GT clone. How can it still be an original 6 after replacing almost everything on the car including 1/3 of the body?
watsonrx13
Mar 16 2010, 03:19 PM
QUOTE(Zundfolge @ Mar 16 2010, 04:16 PM)
-- Rob
Frost
Mar 16 2010, 03:43 PM
I would say yes too.
pete-stevers
Mar 16 2010, 03:48 PM
my thoughts being what they are worth...
if it was a mint matching num six...no
but non matching, needing lots of body work, yes
kconway
Mar 16 2010, 03:53 PM
You haven't got any stock fenders anyway, anything you do won't be original to the car. I say do it if you like the look.
MikeSpraggi
Mar 16 2010, 03:55 PM
For the car in the photo, yes. You need to do a lot to the car to begin with. With non-matching numbers I don't see it as a loss to the small number of all matching 914s left. After all, the factory added flares to 914/6's didn't they?
badm
Mar 16 2010, 04:33 PM
You know you want to!!!!!!
Mar 16 2010, 04:45 PM
Flare it!
bembry
Mar 16 2010, 05:34 PM
QUOTE(dr914@autoatlanta.com @ Mar 16 2010, 01:59 PM)
+1
rfuerst911sc
Mar 16 2010, 05:52 PM
I say go ahead and install the flares.
URY914
Mar 16 2010, 06:20 PM
Flare it.
viaverde
Mar 16 2010, 06:58 PM
I say do it the way you envision it....if you are considering it, you probably want to do it that way.
Flare it.
ViaVerde
Cairo94507
Mar 16 2010, 07:03 PM
I say flare it given that you have to do fenders anyway. I love the M471 look; it adds some real nice curves and shadows.
messix
Mar 16 2010, 07:17 PM
the real question should be "should i waste a perfectly good set of steele flares on the this pile?". that pile is lucky it's a orig. six, if it were a 4 out here it'd be cut up allready.
Socalandy
Mar 16 2010, 07:32 PM
Thanks for the other 22 possitive responses.
I've seen far worse cars brought back from the scrap heap. Other than the rear fenders being removed its a very solid car.
Sleepin
Mar 16 2010, 07:38 PM
QUOTE(messix @ Mar 16 2010, 07:17 PM)
Wow. Did the piss in your Wheaties taste that bad?
charliew
Mar 16 2010, 07:51 PM
That car really looks like there is lots more problems waiting till you get the fenders on to show up. Thats not my idea of a starter car for flares but go ahead and try to save it if you can. Judging from the completely gone rear trunk floor it would not supprise me if there is serious rust in the front trunk channels under the rubber and inbetween the fender and cowl and in the headlight well area. I will also bet it's rusted from water leaking in the rear window. The original 6 kinda gives it a little something. I hope you aren't paying someone to do the work. I would have never expected a ca. car to be that rusted out.
Socalandy
Mar 16 2010, 08:00 PM
I'm doing the bulk of the work and all the areas you spoke of are in good shape. why it was cut up and left this way will never be known but it has good bones
Tom_T
Mar 16 2010, 08:06 PM
Geez Louise Andy - now I see why you said it would take you several years to do it!!
... talk about resurrecting from the dead & I thought mine needed a lot of work!
With that much mod to repair the rust damage, I'd say gor for the YELLOW GT or M471 clone you
really want anyway!
My personal preference is a stock 6 with perfect Mahle Gas burners & period Michelin XZX 185/70VR's!! ... & that would be in one of the blues! - neither of which are your preferences!
Tom_T
Mar 16 2010, 08:09 PM
QUOTE(messix @ Mar 16 2010, 06:17 PM)
Aw - you Colo guys are just
happy!
markb
QUOTE(Zundfolge @ Mar 16 2010, 01:16 PM)
IronHillRestorations
Mar 16 2010, 08:29 PM
That car definately, but I like widebody 914's
jonferns
Mar 16 2010, 08:32 PM
I vote for flares, only because its already a mess
messix
Mar 16 2010, 08:50 PM
QUOTE(Sleepin @ Mar 16 2010, 06:38 PM)
i should have added this
messix
Mar 16 2010, 08:52 PM
QUOTE(Tom_T @ Mar 16 2010, 07:09 PM)
happy!
hey!..... i'm in soggy washington state ... seattle area. rust happens in seconds up here!
EdwardBlume
Mar 16 2010, 08:59 PM
"Do it"
Socalandy
Mar 16 2010, 09:05 PM
but you called my car a pile. I thought this site was for 914 fans, getting help and sharing what were doing with these cars.
messix
Mar 16 2010, 09:20 PM
QUOTE(Socalandy @ Mar 16 2010, 08:05 PM)
please don't take offense to my envious comment, i wish i had a pile of a og six!
really it's your car, it's not a good survivor, it's a resurection of a car that would typically be scrapped.
so build it the way you dream it should be!
JRust
Mar 16 2010, 09:29 PM
I voted yes only because it is not going to be original anyway. If you had the original motor & could go original with it. I would not flare that six but try to bring it back to it's original form. With it not being original & needing to replace the fenders anyway. Screw it
Got to town! Just make sure you go 3.2 or 3.6 on that bad boy
nsr-jamie
Mar 16 2010, 09:41 PM
flare for sure and they are factory steel ones too which is even better.
Socalandy
Mar 16 2010, 10:00 PM
this has been my struggle. If I cant find the needle in the haystack " the orig. engine case" and bring it back to factory original how should I proceed.
I dont think I will go beyond a 3.0 so I can use the webers and keep from cutting up to front of the car for oil coolers. thanks for everyones input. If I had case # 4411 I'd have my answer for sure!!
JRust
Mar 17 2010, 12:04 AM
Wow Andy! That is a huge project. I love that you want to save the six. I don't know man i think I would change my vote. If you really want to save the six. I would say do it stock. Even if it isn't the original six motor. A period correct out of another would be almost as good. The reason I would stay stock is because it is such a project. That would be the biggest reason to save it. Otherwise you would be better off just doing a six conversion on a better core body. It is going to cost alot to bring that car to life. Not to mention the time it will take to do it. I would totally applaud the effort of doing it. Just for me it would be to much effort unless stock. An original period correct six would be awesome. Unless it was original I just don't see the high point of saving it. I would just get a nice core car to build to suit yourself. You will save money in the long run & I think be comprable in value.
Again it is your car & you should do what suits you. I hate to see a 914 going to the crusher
. For me I think that is where it would go. There have been quite a few sixes coming up for sale. Most conversions but some very nice ones. It would be tough to rebuild that six for close to what you would pay to have one you could drive right now
. Your current 4 is a beauty
RON S.
Mar 17 2010, 06:11 AM
I voted yes,
I bought my 914/6 back in 1998. It looked worse than your car does now. It was truely left for dead, and it even had been converted to A 4CYL.
I figured WTH, as bad as my rust bucket was, build it the way I want to be seen driving it.
12 years, and $$$$$$$$$$$$$$$$$$$$$$$$$later,
here's what you'd be staring at in your own driveway.
Ron
davidj
Mar 17 2010, 08:19 AM
QUOTE(Zundfolge @ Mar 16 2010, 02:16 PM)
JmuRiz
Mar 17 2010, 10:44 AM
QUOTE(Socalandy @ Mar 16 2010, 08:00 PM)
There you go, close enough answer for me, go for the flares, it needs work, and won't have the numbers-matching engine...why the heck not.
oldschool
Mar 17 2010, 03:11 PM
QUOTE(viaverde @ Mar 16 2010, 05:58 PM)
Flare it.
ViaVerde
Dude I'm down the street from you...well almost (Pomona)
JRust
Mar 17 2010, 08:22 PM
QUOTE(RON S. @ Mar 17 2010, 04:11 AM)
I voted yes,
Ron
Talk about screwing a poll! How could anyone see what you did with your car. Then not vote to flare it. Yor car is flat out beautiful Ron
Elliot Cannon
Mar 17 2010, 08:39 PM
Restore the car the way YOU want it to be.
Not the way others think it should be.
EdwardBlume
Mar 18 2010, 07:49 AM
EdwardBlume
Mar 18 2010, 07:50 AM
BTW - Ron S. has an awesome car. Look at the rear of that thing... what a great look!
