QUOTE(Eric_Shea @ Mar 19 2010, 08:27 AM)
They used them on different cars (rears applicable). The fronts are a VW caliper made en-mass.
The rears are not interchangable left or right however, there was a Fiat model that mounted them the other way (very similar to the way the Ferrari used the same caliper as the 914-6, just mounted upside down with the bleeder at the other end). Alfa mounted a similar version of our rears at the top and on the transmission... those had bleeders on the top.
The fronts, while listed as interchangable (and I see no reason why you can't), are directional in the sense that one of the bleeders rests deeper in a rounded recess area. I always load the pistons so this bleeder is on top.
So does that mean I can plug the the lower bleeder?
