QUOTE(ldscamaross @ Mar 20 2010, 12:14 AM)
im using bus axles with a subaru tranny. so the 944 stub axles dont fit into the 914/4 rear hubs?
They do fit but they need a spacer otherwise the bearing is not tight and will move in the trailing arm.
Do a search here, this has been covered before with pics and dimensions needed for the spacer ...
If i recall correctly, the thread for the axle nut is longer too and may stick out too much, depending on your wheels etc.
I'm too drunk right now to look it up for you.
Andy
