Pulled the tank last night, replaced lines, fuel pump, put tank back in, put some fuel back in, hooked the battery back up.
Crank, crank, crank, crank
Hmm, nothing
More cranking
More nothing.
Hmm.
Doh! Forgot to hook those little ground wires on the engine block from the FI harnes. Duh!
Crank, VROOM!
Drove it around last night for a little while, filled the tank. I know I have to adjust for a 1.8 FI system on my 2.0, but seems pretty smooth.
One issue I have noticed, my throttle takes a Looooooooooooooooooooong time to return to idle. It's smooth, just seems to take forever, like I don't have a spring. I do have a spring from the arm to the plenum. Should there be another spring?
Anyone have any pictures of L-Jet throttle return srping set-ups? Maybe I don't have it on correctly?
In the end, I'm really glad I bought new injectors, all new fuel and vac lines and a new fuel pump along with other little things. Eliminates many possible issues.
I did drive it into work today, started right up this morning, nice idle. Sans the throttle return issue and just setting it for 2.0 liters, I think it's good to drive!
