QUOTE(synthesisdv @ Mar 29 2004, 07:55 PM)
send some this way, that is what I was thinking about.
have you tried both types? Is the nylon mount almost as rigid as the aluminum?
thanks,
dr
The nylon is pretty rigid, but it does attenuate quite a bit more noise and vibration than the aluminum.
It is hard to compare to polyurethane, as nylon is plastic like and the hardness is measured with the Rockwell R scale. Polyurethane is considered like a rubber (and can range greatly in how hard it is from squishy soft to plastic hard) and is measured by its durometer.
