machina
Mar 30 2004, 07:04 AM
I know its tricky getting a full flow oil cover plate to clear on a 914.
What exactly gets in the way, do you have to remove material from the mounts, the case, the car, the crossbar?
Who has BTDT?
thanks,
dr
DNHunt
Mar 30 2004, 07:11 AM
Man that's starting to look cool. I'm just guessing but how about the engine mounts.
Dave
machina
Mar 30 2004, 07:25 AM
BTW,
that's not my motor, but mine won't look much different.
dr
Jake Raby
Mar 30 2004, 08:35 AM
The engine mount on the left side of the oil pump will have to be hacked up and rewelded.... and a 45 degree fitting added to the pump instead of a straight one.
That engine uses MY DTM, see the mounting plate on top of the case....
cha914
Mar 30 2004, 09:32 AM
Seem like it would be easier to just make a new engine mount bar. I have seen some v8 cars use 1x2 tubing to make mount bars...easier to cut at weld if you still need clearancing, and it might actually come out lighter than the stock bar. However, I donno how that would clash with the race rules in your class.
- Tony
