McMark
Apr 2 2010, 10:55 PM
Whew! Just finished typing my most in depth addition to the
Parts Vault. This is the type of article that I imagine the Parts Vault someday being more like. Someplace members can read about how each and every component on a 914 works, how it breaks, how to fix it, etc. It's a ton of work, and I'm still trying to figure out how best to organize this information so it's easier to find. But at least I'm getting the info typed in. Trying to do a couple of parts per week.
Fuel Tank Level Sender
Mike Bellis
Apr 2 2010, 11:56 PM
Thanks Mark, mine stopped working yesterday after I removed it from the tank. Now i will see if it can be fixed.
Mike Bellis
Apr 4 2010, 03:41 PM
I pulled it and cleaned it as you described. If I operate it out of the tank, opened up, It will read correctly as I move the float. If I put it in the tank, with 3/4 tank, it reads empty! I am using an Autometer programmable gauge. My next step is to replace the ground wire and sender wire. Like I said, it works out of the tank, just not in the tank. If it's not the wiring, the float is sinking...
