QUOTE(kg6dxn @ Jan 21 2011, 06:07 PM)
The gel is an Evercoat product. I get it at Kragen with my kitty hair. I mix the two to get the kitty hair to flow better and be less porous. The ABS housing is thin and has no structure once cut to fit. I build up 1/2 to 3/4 with kitty/gel. This makes it a solid piece to work with. The mix I use is 50/50 kitty/gel. This take most of the porosity out of the kitty hair and is eay to spread. I build it up before I cut anything. It really make the piece easier to work with. Dust mask needed! Keep away from where the lamp bolts into the fixture. I use L brackets with rivet nuts in them, bolted to the stock headlight mounting holes. Dry fit the brackets, then put a wad of kitty hair on the top of the brackes and place the fixture on the car. Let dry and unbolt. Brackets should be attached. Trim and re-apply kitty as needed to make nice.
Just ordered mine today and hope to have them on by spring. You're an inspiration!
Do you have any notes on the wiring?
