Its for the SDSefi to control the fuel pump. It will turn it off if the engine doesn't turn over
Jul 11 2010, 09:45 PM
QUOTE(Teknon @ Jul 11 2010, 08:10 PM)
Then use the stock fuelpump relay. If you jumper the old FI connector (as if you were running carbs) the stock fuel pump wires will give you switched 12V ...
