QUOTE(Krieger @ Jul 17 2010, 09:29 AM)
Find someone on this thread that is cutting up a car. You need a little more metal than just that part.
You've got that entire pan section rusting off & may lose that side of the suspension on a corner or something. I think that the windshield washer bottle/hoses leak from above that point & rust through there as the low point on that side of the fuel tank compartment.
Here's a pic of what happened to mine just sitting on blocks in my dry SoCal garage for 25 years 85-09/10 - & my 914 had a complete $6500 resto & full running gear & suspension overhaul between 80-84, so I know it wasn't that way when is was put up for storage! The bolt is still solid & threaded, but the pan around the support strut is toast!
I think you've probably got the start of what my pic shows, if you start poking around with a screwdriver, which is how I opened this +/- 2"x4" "L-hole" up to assess the extent of the rust damage.
Click to view attachmentClick to view attachment
