QUOTE(vsg914 @ Aug 19 2010, 01:46 PM)
QUOTE(EdArango @ Aug 19 2010, 01:24 PM)
QUOTE(Cap'n Krusty @ Aug 19 2010, 11:15 AM)
Uh, why did you drain the gas tank?
The Cap'n
the reason why i drained the tank was because i followed the pelican parts tech articles way of removing a 914 engine and it said that it was better for the gas tank to be drained
That might possibly be the stupidist thing I've ever heard.
Pelican makes it a whole lot harder than it has to be.
Well, considering that most people have to drain gas in the tank at sometime during a restoration (or it will rot and gum up the fuel system) it is a pretty far from stupid suggestion. By draining the tank, you can burn the gas in your DD before it goes sour, and not have to worry about potential fires while you are working on your car.
I don't think that it is a bad thing to do.
Anyway. Once you get the shifter bar and CV's loose, the rest is pretty easy. If you use one of Chris Foley engine lifting plates, the whole process becomes MUCH easier! Remember, you do not need to remove the heat exchangers or muffler - only the flex hoses that connect it to the cabin heating system.
Zach
