QUOTE(914rat @ Aug 19 2010, 11:07 PM)
Did some top end work and reassembled the motor installed new SVDA dist on my 2056 with 40 dell and can't get her to start.Got spark and fuel but no start.Is it possible to install the dizzy wrong?I followed the instructions from the supplier and the Haynes book.
There is a offset tooth that inserts into the distributor drive pinion. It is offset so that you cannot install the distributor 180 off. If you pulled out the drive pinion, you could easily re-install it wrong. If you took your distributor apart, you could have installed the toothed part at the bottom of the dizzy backwards (I did).
Make sure that the distributor is in tightly and that the tooth is inserted properly in the pinion. Grab the rotor and make sure that you cannot turn it. If you can then it is not in properly.
Disclaimer- I am defiantly not one of the forum experts.
