If you have a facet pump you must have carburetion. The fuel pump will not work with stock wiring unless you have the control unit hooked up.
You can jumper the main power relay position to the fuel pump relay position and have the facet run when you turn the key on though sans control unit
QUOTE(914rat @ Aug 30 2010, 02:32 PM)
Just did it last week and no fuel.I can hear the relay click but no fuel.Put 2 male spades on the wires coming from the facet fuel pump and plugged them into the factory plug.Ran a jumper from the relay box to ground.Seemed simple enough.What's up, any ideas.
