The right front caliper was sticking on my 914. I pushed the pistons back in about 10 times and it hasn't stuck since then.
At this point I would be afraid to drive it a mile down the road let alone 60 miles to Vonore not knowing if the brakes will work properly or not. I did push the pistons out a few times and they seemed to loosen up but can't be sure what might happen when driving.
Plus, the accelerator pedal rod pops off after a few minutes of using it due to the fact that I had to bolt the pedal to the rusted floor with a single bolt/washers combo. One of the original bolts is rusted to the floor and the other is broken off. So the pedal twists a bit and the rod pops off.
