QUOTE(markb @ Oct 17 2010, 10:31 AM)
QUOTE(Gint @ Oct 17 2010, 07:27 AM)
87 octane for a 1,7 is just fine.
Update :
when i toolk off the valve cover, i tested the gap and found that they were off according to the instructions from pelican forrum they were all tight (no space ) at the tdc. that was the case for all 8 of them.
I did the adjustment as instructed.
after the adjustment, the pressure test stays the same as before, except that 3 went up to 135
new test result:
1: 90
2: 135
3: 150
4: 150
I put everything back togetter and attempted to perform a timing test. Unfortunately the timing light did not come on at 3200 rpm or above.. its a brand new light, not sure if its deffective. I replaced the fuel with 93 premium.
1- The car did perform better. didnt loose power as much, or maybe not at all. but after 10 minutes of driving, i started hearing the ratling again and the smoke comes back.
2-I noticed this time that the smoke was coming out of the mufflers and the where the pcv valve should be. but there was no pcv valve. it is empty.
3-I have an other problem with the number one spark plug. it look likes it was stipped by the previous owner, the plug refuses to go in straight and you can see that it does not go all the way in.
4-one of the passenget side push rod is leaking
5-the engine is a noisy and sound like an exaust problem.
I think I corver it all..
I am not sure that i was using the right timing light.. I picked up one at autozone.
