QUOTE(euro911 @ Oct 17 2010, 04:58 PM)
QUOTE(Vacca Rabite @ Oct 17 2010, 07:14 AM)
Oh, and before you ask, no you do not need to remove all the exhaust stuff first. Yes, it sucks the first time but it gets easier. You hands learn where they need to go.
Hopefully you won't need to drop the drive train (this time) ??? ... that might depend on the outcome of your valve adjustment.
However, if you DO, I've always found it beneficial to remove exhaust systems prior to dropping the drive train. It's easy to get to all the exhaust's components while it's in up there the car (and on jack stands). You just don't have that ground clearance after you drop the drive train on to a dolly.
Once it's on a dolly, you just need to remove the peripheral components, induction system, cooling tins and then start the head removal process.
Ideally, once it's out, separate the transaxle from the engine to inspect the clutch components, flywheel, seals, etc. ... and replace as needed.
Different folks do things differently
Update :
when i toolk off the valve cover, i tested the gap and found that they were off according to the instructions from pelican forrum they were all tight (no space ) at the tdc. that was the case for all 8 of them.
I did the adjustment as instructed.
after the adjustment, the pressure test stays the same as before, except that 3 went up to 135
new test result:
1: 90
2: 135
3: 150
4: 150
I put everything back togetter and attempted to perform a timing test. Unfortunately the timing light did not come on at 3200 rpm or above.. its a brand new light, not sure if its deffective. I replaced the fuel with 93 premium.
1- The car did perform better. didnt loose power as much, or maybe not at all. but after 10 minutes of driving, i started hearing the ratling again and the smoke comes back.
2-I noticed this time that the smoke was coming out of the mufflers and the where the pcv valve should be. but there was no pcv valve. it is empty.
3-I have an other problem with the number one spark plug. it look likes it was stipped by the previous owner, the plug refuses to go in straight and you can see that it does not go all the way in.
4-one of the passenget side push rod is leaking
5-the engine is a noisy and sound like an exaust problem.
I think I corver it all..
I am not sure that i was using the right timing light.. I picked up one at autozone.
