Thread bump with my solution to this problem.
@superhawk996 this is for you bud. :-)
The finished product, with and without bikes.
My goal was to have a rack strong enough to mount 2 heavy-ish bikes and front wheels on m 914 so I could drive hundreds of miles away from home for bike camping car trips. AND, the top had to be removeable with the rack in place.
I used the 6 existing ski-rack mounting bolts and fabbed up the bar using a Thule bar from my very first car back in 1998 that has somehow stuck with me for the past 24 years. This pic is the MK2 mount I fabbed, as there is a requirement for spacers in order to clear the chrome targa bar trim. In this pic the mount is only tacked together and held with one loose hex cap screw for fitment. One of the tricks that came up was that the mount had to be at an angle to the Thule bar, to match the slight curve of the Targa.
Almost all the non-home made parts came from
https://www.backcountry.com/.
I used fork mounts simply bolted to the bar to hold the bike at the front, and QR wheel mounts to hold the front wheels.
To hold the back tires to the car I used suction cup rear tire mounts. They work really well.
Here you can see that the clearance is TIGHT with my ancient Iguana mounted to the rack. In fact I chipped some paint taking the roof off and putting it back on. BUT I COULD AND DID TAKE THE ROOF OFF. If I were doing it again I'd make the mounts I fabbed up about an inch longer. But I was concerned about having too much of a lever pushing against the mount, and I also needed to be able to clear the spoiler for the rear tire. Also, I quickly realized with the 914 loaded with a tent, cots, sleeping gear, a cooler spare clothes, eating gear, and 2 people there was nowhere to put the roof anyway once removed.
Again, not a lot of room to spare with the spoiler in place. This pic also shows the beefy suction cup mount used to secure the rear of the bike to the car. The trunk cannot be opened while bikes are mounted - pack accordingly!
both bikes and both wheels mounted. The mount is strong, with minimal sway of the bikes while they are on it - no more then any fork mounted bike. I did not hammer any twisties with the bikes on the car.
Loaded with the bikes, and all the camping gear the car was HEAVY. It is sitting visibly lower then usual. Both trunks were filled, with the spare tire moved to the rear to make space up front for the cooler.
Driving the car fully loaded like this was disconcerting at first. But the night before the "big trip" I loaded the bikes on and did a late night blast up I83 about 40 miles. The bikes add a LOT of drag, but I was still able to drive the car about 85-90mph without issue aside from the CHT gauge going a bit higher then usual.
For the trip (about 150 miles one way) and loaded with all our camping gear, I drove it a lot more like a bus then a sports car for most of the trip. But I was still able to keep it at about 75 on the free way, and drive to the CHT like you would a bus. I was a good bit more ginger on the curves then usual.
My car usually get attention when I drive it. But my car with BIKES on it got a ton of attention. One guy we drove by pointed and yelled loud enough that we could clearly hear him "Holy shit, that little car has bikes on it. Thats cool!"
I will be changing things up a little bit this year (maybe). I bought a new bike (first new bike in 22 years) and it uses through axles rather then Quick Release tabs on the forks. But this will be a simple change up.
Zach
