Nov 7 2010, 11:51 AM
Wonder how many page views I'll get with this title?
colour scheme by Don Johnson?
jaxdream
Nov 7 2010, 12:09 PM
Toyz r Us ???
Jack / Jaxdream
Nov 7 2010, 12:23 PM
It's not my style but when you see the car, it makes sense. History and specs are what counts. I plan to remove colors and leave plain or powder coat black. I wasn't planning on buying an engine for the car- yet, but this was too good of an engine for too good of a deal to pass up. I would have bought it if it was pink and purple polka dots. Hey,
carr914
Nov 7 2010, 03:27 PM
scotty b
Nov 7 2010, 05:08 PM
Matte black tin and glass beaded intake, fan & valves
THIS will be fun
Nov 7 2010, 05:21 PM
QUOTE(scotty b @ Nov 7 2010, 06:08 PM)
THIS will be fun
Engine shroud is black.
Do you have a bead blaster?
Maybe I should grab an oven from one of my distress properties and try some DIY powdercoat.
scotty b
Nov 7 2010, 06:06 PM
yep ogt a blast cabinet all loaded with glass bead. If the parts are powder coated they need to be chemically stripped.Blasting won't do it. I have the stripper, the pieces need to soak ( usually overnight will do ) then scrubbed clean, washed and then blasted.
Eric_Shea
Nov 8 2010, 12:51 PM
Red Shroud.
Nov 8 2010, 02:07 PM
QUOTE(Eric_Shea @ Nov 8 2010, 01:51 PM)
Red Shroud.
Quiet you. I might be sending more money your way when I decide what to do with my new '75. Damm car has so little rust that I might just keep it and restore. Damm you Eric Shea and your perfect brakes! Damm you all!!!
JmuRiz
Nov 8 2010, 02:27 PM
QUOTE(scotty b @ Nov 7 2010, 03:08 PM)
THIS will be fun
Sounds good, my 2.7 has black valve covers with paint peeling, I was thinking of stripping the paint off an just going au-natural with the alumn.
Eric_Shea
Nov 8 2010, 03:18 PM
Don't forget that 5-lug stuff
ghuff
Nov 8 2010, 03:47 PM
Your motor is from Jamaica mon!
PanelBilly
Nov 9 2010, 08:49 AM
What the hell, the car is getting a six that is not OEM, so paint it whatever color fits your fancy. I like the wild stuff.
Nov 9 2010, 09:11 AM
Car will stay same color red, engine- silver and some black. I'm boring.
VaccaRabite
Nov 9 2010, 11:18 AM
Don't go black.
Go with something that reflects light, not absorbs it. The engine compartment of a 914 is a dark enough place to try and work, painting it all black only makes matters worse. Plus, black hides the oil leaks and gunk buildup.
Zach
Nov 9 2010, 02:47 PM
engine tin = black
type47
Nov 9 2010, 05:05 PM
Nov 10 2010, 11:05 AM
more pics of the bitch
