The Challenge:
Take a car that you have never driven (except for 10 mintue test drive) or worked on or even barely seen before...
Completely tear down every nut and bolt on car to bare body!
Sandy blast, repaint, reassemble exterior and interior.
Completely tear down engine
Clean, rebuild, reassemble engine (tricky part because old wiring was a mess, fuel pump was running off coil, cold start valve running all the time, temp sensors were disconnected, fuses blown, hoses missing....you get the point)
Install engine
Install all new hoses and fuel lines (harder than it sounds)
All done in 17 months 22 days
and then......and then....
The Result:
pour gasoline into tank
get two fire extingushers just in case....
install battery
turn key......and then....and then....
wait for fuel pump to prime and shut off.....done
depress clutch (even if car is on axle stands)
turn key one more notch......nothing.....try again....nothing...back key off to off position and try again....nothing
crawl under car to look at starter, ah ha. solinoid wire was off.
get into car and turn key
It didn't take but 1 1/2 seconds and bang bang, as in chitty chitty, and it was running!:rockin:
It's a little noisey but I still have to time it and test run it and bring it up to temp but for now....IT"S ALIVE!!!!!
I have one beer left in the case and I am now going to celebrate.
Thanks to all on this site who have helped me along the way. I salute you!
