ok so heres the update.
heres what we got done:
removed front a arms and replaced bushings (new URO's) thanks Eric Shea
followed the instructional video and it worked great. instead of a press we used some PVC plumbing adapter pieces, one size to push on the collar, and one size to push the bushing onto the arm. then used a floor jack to push the assembly up against the bottom of the lift with the car on it. lots of soap and telling the bushing how we would by it dinner and viola...they went right on
installed the new bilstein strut inserts in the front man they are purty.
replaced the front rubber brake lines
swapped out the rear shocks with bilsteins and 100 lbs springs
unfortunately the bearing replacement did not go well.
i bought replacement bearings for a 74 914 but apparently, that is not what i needed. with the new bearings installed on the rotors, the back of the rotor is hitting the splash plate mounting bolts
thinking i had somehow got the wrong bearings, i found out the sell 914 bearings at autozone!!
the one place i didnt check for them! so i quickly got a 2nd set of bearings and got them back to Cesar's. but upon measuring them, we found they were the same size as the previous set made by NTK (i think) but both of these measured 1/2 a millimeter smaller then the original bearings we removed.
well thats great. keep in mind this car is in the middle of Cesar's garage so we needed to get it mobile again.
well with the splash guards removed the rotors spun freely so i left them off so we could get the car out of there and reassembled it.
now for the funny part. one of the things i failed to mention earlier is the car has been missing the grease caps on the front end since i got it
i got some from good ole Bruce and planned on installing them when we got the front end done...Wrong! the grease caps do not fit on the rotors!
we got the car back together and bleed em and i drove it home(by now its almost 8pm) on the short drive i noticed when turning the front end would wobble and clunk..YIKES!!! its new safely back in its nest that is formerly known as my garage and i will be going back at it soon
what the hell rotors do i have?
the saga continues
i will most likely post a new thread with some pics as soon as i get it apart again
tune in next time...same bat time...same bat channel...
