QUOTE(914Sixer @ Jan 2 2011, 09:15 AM)
I thought I would go out to the shop and do a little work yesterday. I had a set of hubs I picked up that needed cleaning up. I pressed out the studs and old bearing races. Cleaned the studs and did the black oxide treatment to them.I had the hubs in the parts washer to get the gunk off. Cleaned as much as possible, then off to the bead blaster after I taped everything up. From there I took them to the wire wheel and polished them up. Then two coats of baked on high temp caliper clear. I know they will be unseen parts but I know they have been done to my satisfaction. My wife says I an getting OCD in my old age.
..............You did a great job, they look great. And as you said you have the satisfaction of knowing they have been done right.
