8 Hours Later, Probably A Little Over the Top |
914Sixer |
Jan 2 2011, 08:15 AM
I thought I would go out to the shop and do a little work yesterday. I had a set of hubs I picked up that needed cleaning up. I pressed out the studs and old bearing races. Cleaned the studs and did the black oxide treatment to them.I had the hubs in the parts washer to get the gunk off. Cleaned as much as possible, then off to the bead blaster after I taped everything up. From there I took them to the wire wheel and polished them up. Then two coats of baked on high temp caliper clear. I know they will be unseen parts but I know they have been done to my satisfaction. My wife says I an getting OCD in my old age.
detoxcowboy |
Jan 2 2011, 09:05 AM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Sixer (Mark?),
I think your wife is right! But that is why when your selling anything, I am always in line to buy from you.. Those look sweet!! If you really have OCD ( I have been told same.) then it does not matter if anyone can see what you did, as long as you know you did the work to your satisfaction.. Good Job!! Joe |
ME733 |
Jan 2 2011, 09:38 AM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
I thought I would go out to the shop and do a little work yesterday. I had a set of hubs I picked up that needed cleaning up. I pressed out the studs and old bearing races. Cleaned the studs and did the black oxide treatment to them.I had the hubs in the parts washer to get the gunk off. Cleaned as much as possible, then off to the bead blaster after I taped everything up. From there I took them to the wire wheel and polished them up. Then two coats of baked on high temp caliper clear. I know they will be unseen parts but I know they have been done to my satisfaction. My wife says I an getting OCD in my old age. ..............You did a great job, they look great. And as you said you have the satisfaction of knowing they have been done right. |
TC 914-8 |
Jan 2 2011, 10:22 AM
Senior Member Group: Members Posts: 809 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest |
My wife says I an getting OCD in my old age. Good Job, if you own a Porsche, and don't already have OCD, You will get it!! (IMG:style_emoticons/default/first.gif) |
Rleog |
Jan 2 2011, 10:29 AM
Senior Member Group: Members Posts: 608 Joined: 12-October 03 From: Middleton, MA Member No.: 1,239 Region Association: North East States |
Great work, even if it is a little over the top. However, whenever you take a wheel off, you get a little extra satisfaction gazing at those hubs.
dadaDaveed |
Jan 2 2011, 10:32 AM
Member Group: Members Posts: 111 Joined: 19-February 09 From: San Antonio, TX Member No.: 10,071 Region Association: Southwest Region |
Hey those look very similar to mine. (IMG:style_emoticons/default/shades.gif) (I got my 5-lug pieces from Mark). Now, let's hide those pretty hubs behind some wheels and make it em' spin!
-DB |
Lo-Fi Version | Time is now: 18th May 2024 - 09:41 PM |
