Hi All:
I would like to install an early version 2 liter engine wire harness (one that includes brain connector) probably from a 1973 car on a later 2 liter engine. ('am doing this because the wrong year early harness is in much better condition that the correct year original harness).
So far it appears there is one difference, I'd like to know if anyone out there knows of any other difference that would effect me running a later (possisbly a 1975) FI system with a 73 harness.
The one thing different between the two harnesses I've found is the cold start thermal switch is a two wire sensor on the later engine, the early harness has a is a single wire. From the schematics, I think all I need do is swap out my two wire sensor for a single wire sensor, and every thing else should work.
Is swaping out the sensor all I need to do?
Is there anything else I should check for in this harness swap?
Anyone do this before?
thanks dave
