Painting is tough. Super In Law and I were talking about that yesterday while I'm painting a bumper for a 2000 Honda Accord for my son's girl friend.
Taking it from gold to dark green. Sand down the couple scrapes (plastic). Grab a can of U-Pol primer from the paint cabinet. Cover up the sanding work. Wet sand it smooth.
Shoot on the Deltron sealer. Gun is spitting a bit.
I paint about once every two years. So that has to be wet sanded. After the fact. I run some solvent thru the gun to set the pattern and density.
DumbassThen I shoot the coat of color, Deltron DBC.
Man its a lot easier shooting a dark color. You can see it covering and laying down All my cars are white.
I'm telling myself tack coat, tack coat. Its going on real nice.
Then I see the reaction starting in a couple spots. Dammit ................ What did I do wrong THIS TIME? Its right in the spots where I applied the primer. Did I not let my cleaner flash off before I started shooting the paint? Dammit ................It was going on so nice.
Dumbass ............... remember that can of primer? It was weld thru primer that I put in the paint cabinet rather than out with the welding stuff. Rule number 1. Don't mix brands of paint systems. But my PPG paint store sell/pushes House of Color primer with the Deltron 2000. So being lazy on small jobs I use a spray can for primer. Usually SEM.
But I liked the way the U-Pol clear coat laid down on my 911 rocker panels. Now the question is. If it will wet sand out. Should give the bumper another coat of color and clear over it. Or will the primer gas thru the sealer, paint and buger up the clear?
That " no mixing brands of paint " is way overblown IMO. Yeah there can be issues, but more often than not, if you know and understand the chemistry, it can be done without issue. The real issuie is mixinf TYPES of paint, not brands. The problem you had is with the chemicals in the weld through reacting with the base. My reaction would be to sand it ALL off and start over. I'd be concerned about the weld primer coming back later when the sun gets the bumper good and hot
