yeahmag
Feb 18 2011, 11:25 AM
Been driving the 914 for a few weeks while I slog through my Subaru's head gasket repair. On the way to work yesterday the clutch goes "POP!" and looses about half its adjustment. I figure the cable is done for and buy a new one. No biggie...
Turns out the clutch tube broke away from the tunnel. So now I get to join that club. 2 cars down. All I need to do now is get some cinderblock and push both of them on to the front lawn...
bandjoey
Feb 18 2011, 11:27 AM
Temporary repair with a U Bolt...keep it running.
Krieger
Feb 18 2011, 11:31 AM
I heard a wise man once said: steel sharpens steel.
underthetire
Feb 18 2011, 12:51 PM
I feel your pain. 914 has head problems, my Jeep last week lost, fan control relay, emergency brake, and passenger side window regulator. I have vise grips holding up the window, but it's raining like hell here, and there is still a nice little gap for rain to get in to.
JeffBowlsby
Feb 18 2011, 02:21 PM
If its the front of the tube that let go, its an easy job actually.
yeahmag
Feb 18 2011, 05:22 PM
Hoping to just plug weld it too... I all ready have SS lines, so risk of fire is a bit lower...
yeahmag
Feb 19 2011, 12:10 AM
Jeff,
It looks like you just plug welded right to the tube itself. That's what I was considering as I'm assuming the bracket won't be in good shape. Any draw backs to that? I have a friend that is a professional welder bringing his TIG by to help, so heat control should be a non issue.
yeahmag
Feb 19 2011, 03:45 PM
...and its loose at the firewall too. Good grief.
yeahmag
Feb 22 2011, 01:35 AM
What a day! Was able to finish the 914 AND the Subaru. A good friend came over with a portable TIG and we plug welded the bracket at the front of the clutch cable and used a very heavy washer "kustomized" to fit on the rear at the firewall. Clutch feels amazing! I had no idea how bad it "was".
Subaru fired up first crank and no leaks. PS pump is a little noisy, but I either damaged it using that belt and pulley to remove the crank pulley nut or the belt is a bit loose (or it needs the fluid changed). In any event. It lives!
jaxdream
Feb 22 2011, 07:37 AM
Congrats
, that's just gotta feel great !!!To have both fixed at the same time .
Jack / Jaxdream
