QUOTE(McMark @ Feb 21 2011, 04:02 PM)
I understand the internals would be spinning opposite of their designed intent. But just as a mental exercise:
If you install a 911 transmission in a 914 (type 4, etc) you get 5 'reverse' gears.
If you then install a Corvair motor and spin that transmission backwards, don't you get 5 'forward' gears?
It's still running on the 'backs' of the gears, but wouldn't flipping the diff be counter productive?
I shouldn't post because I'm talking out my ass. Pfffphbbrfft.
But another mental exercise:
In both the 914 and 911, the main gear stack is rotating the same direction. The flipped diff is the diff(erence).
So a 911 tranny in a 914 still has the main stack going the correct direction... Just the diff backwards.
Spin the whole thing backwards and that makes up for the diff diff, but the core stack is now backwards.
So yeah, Corvair motor plus 911 tranny = 5 gears forward and 1 reverse... But after all of this shell game, the core stack is backwards... Which is said to be bad?
If two wrongs makes a right, does a wrong plus a wrong plus a right make everything wrong but actually right because it is anti counter productive?
This will make more sense after I have a beer.
understood what I was trying to say.
