QUOTE(SLITS @ Mar 23 2011, 08:06 AM)
1.7 Type .... Should work if that's what you need .... WorldPac/Beck Arnley ... different side of the same coin.
Bum advice, Slits. It has the electrical plug configuration for a 1.8 or some other later model, like a VW Bus/Vanagon. That said, it'll work, and the D-jet connector will plug in, just not as well as if it were the correct valve.
BTW, I don't think Beck Arnley is part of WQorldpac, either.
The Cap'n, righting wrongs all over the place.
