I believe it is MSD wires Purple+ , Green- / Distributor Orange+ , Purple-
You can find the install instructions for your MSD at
http://www.msdignition.com/Products/New_Pr...on-Control.aspxI think you can run the white wire on a switch to ground for an ignition cutoff
Also to prevent run on, a one way diode is sometimes needed in the alternator circuit, i think i put mine in on the blue wire that goes to the alternator gauge light.
