I'd like to do this only once so:
Replacing KYB's with Bil's, not changing springs (100 Lb, about 12 years (15-20K miles) old). As I visualize the setup for the rear, If I keep the distance from the lower spring perch to the lower mounting bushing the same, the rear ride height will stay the same as before, though possibly a bit higher because of the apparently higher pressure in the Bil's.
Thanks,
Harvey Hoover
