QUOTE(rfuerst911sc @ Apr 20 2011, 09:09 AM)
I have a 1978 3.0 with Weber carbs installed in my 75 GT clone. She runs good but is cold blooded but good throttle response. Engine is stock internally. I just picked up a 3.2 intake setup complete with manifolds,throttle body,fuel rails,injectors and injector harness. So to complete the package I could go after OEM ECU but then I would have to mount the sensors on the transmission. Or I could go aftermarket ECU and just use TPS/MAP. I'm in no rush as this will probably be next winters project. So what aftermarket ECU's do you guys recommend ? I do not want Megasquirt I had a bad experience with that and never again. Also not sure if I want fuel injection only or injection/ignition. I do have a complete EDIS from years ago that could be used. And finally anyone in the Atlanta area that can install/fine tune ? I can install everything but would need help fine tuning. So what suggestions do you have ?
I'm sort of working on the same idea for my 911 using PMO itb's. I'm looking at using the Holley HP EFI ecu. I have a Holley HP on my 914 3.8V6 using a 4bbl tb. The system works very good and once a base map is setup it will self tune from there.
Paul
