I am looking for two cover plates for 40MM IDF carbs.
Simple flat aluminum, 1/2 inch thick, with two holes that will accept IDA (not IDF) velocity stacks.
So, its needs to be the right shape for the IDF.
It would need two holes for the velocity stacks.
It would need a funky hole for the emulsion tubes
I would like to have the outer edge camfered at a 45 degree angle so the horizontal face is 50% of the total thickness.
I need two for dual carbs.
