TravisNeff
Jun 11 2005, 06:25 PM
The kit is great, I concur with Trekkor on the install time. A full day to remove the interior, peel out enough tar and seam sealer, fit and weld.
Wayne, from the look of the lower section of your inner longs, this kit will help out a ton!
grantsfo
Jun 14 2005, 11:25 AM
So its not clear to me. I'm in the process of building a leightweight AX and occasional track car. I will have a cage installed soon. Are there any benefits to using this if I have a well designed cage installed? For me will the 18 lbs of stiffness pay off on a 4 cyclinder car or is this kit primarily aimed at higher hp cars without cages? I guess if I'm going to add weight , adding it low on the car is good.
Andyrew
Jun 14 2005, 11:51 AM
Grant, your car, running hoosiers will greatly benefit from the extra stiffening. The more stick that a car has, the more flex it recieves...
I'd say reinforcements, and a cage will be fine for you... You can always cut out 18# of sheet metal somewhere else!
I will be installing these in my car sometime this year.
ewdysar
Jun 14 2005, 03:30 PM
If your cage will be tied into the suspension points, the inner long kit will be redundant. IMHO, it would be dead weight. It's primary reinforcement is the flex in the longs themselves (eliminated by a passenger compartment cage) and the connection at rear firewall (eliminated by tying into the rear console). So if your cage will be cockpit only, there may be some benefit to the inner long kit.
Of course, this is just in my head... I don't know ****.
Eric
Engman
Oct 9 2005, 09:19 PM
Sale - Inner long kits - $240.00 – limited number of sets available.
My painter screwed up. He was supposed to only ecoat one set and instead he did my entire last batch. Normally this is a $20.00 add to the cost, but since I called him on it I got the extra sets painted for free. Now I am passing the savings onto you. $240.00 plus shipping. First come first serve.
Or - pay full price and get free prioity mail shipping in the continental US.
Mark
GaroldShaffer
Oct 10 2005, 08:37 AM
Mark I will take a set. Sending you a PM also.
Man my winter project list just keeps growing.
seanery
Oct 10 2005, 09:04 AM
Mark,
I want a set.
Can I paypal?
Engman
Oct 10 2005, 01:20 PM
PM's sent!
M
seanery
Oct 15 2005, 06:14 PM
got mine today!
Thanks MARK!
WRX914
Oct 27 2005, 11:35 AM
I have bought two items from Mark, and both items are what the doctor ordered! Mark is a honest man, he delivers exactly what he advertises... Great products Mark!
You da Man!
Keith
Greenbuggy
Nov 2 2005, 01:31 AM
QUOTE (Engman @ Jun 22 2004, 07:38 AM) |
You definately want the pressure off the longs - use the jackstands. (yes there is still stress in the longs on the jackstands- its just much reduced due to the distances of support)
M |
Forgive a guy if these sound like dumb questions - I'll be posting pics/details up soon, but in short - I've got a guy who is paying me to restore his green '72 914 and he also has a parts car. As with all 914's it seems (but especially in the midwest) his car has rust and some sag, and of course that needs to be fixed.
Your products all look good, and I'll probably be making an order for your long reinforcement kit, pedal board and hell hole kit, god knows the car will need all of them. I'm determined to do this car right, and have previously resto'ed a '59 VW Type I chassied buggy that sat outside for 15 years, so I'm intimately familiar with what rust can do on a monocoque chassis and how to fix it.
That said - I have a few technical questions.
#1, I have jacks and jackstands and a smooth concrete floor to work on. Where would you suggest putting jackstands for the long repair, to keep the body straight while doing this repair? I'm guessing at the fronts and backs of the longs, but would like confirmation.
#2, the car needs floor pans repaired as well as the longs repaired. Obviously the longs will get repaired before the reinforcement plate goes on, but would it be easiest to replace the floors before or after the long reinforcement kit goes on?
#3, have any of you who have done this kit use some sort of brace where the targa top would go to keep the body straight up top while welding everything in place?
#4, lastly, I'm concerned about keeping rust away long-term for the owner of the car. I was thinking, after long repair, wire brush to bare metal, coat long in weld-thru primer, lay on reinforcement, weld in place, clean welds, POR-15 over the entire reinforced long assy, seam seal at edges, and final coat with some sort of epoxy based paint. Does this sound good to keep rust away long-term? Keep in mind that the entire underbody is also getting POR-15'ed, and that this is a midwestern car and will likely see rain and quite possibly even a little salt in the coming years.
Greenbuggy
Nov 2 2005, 04:43 PM
One more I forgot - would you recommend doing this kit with the engine in or out of the car? The engine is coming out anyway for the hell hole repair and to get cleaned up.
type11969
Nov 3 2005, 04:05 PM
This is what I have done, but I have a serious hell hole and lower pass long repair (the lower left corner of the left long is rotted through along with the std hell hole rot, I think the PO let the pass. floorboard fill with water, rot away, and then they replaced the rotted floor with a new one without fixing the long). I have a brace with a turnbuckle going from the upper pass. seat belt mount to the upper pass door mount, and another brace with a turnbuckle going from the lower driver door mount to (essentially) the upper pass seat belt mount. Without both my targa bar was not aligned with my windshield.
PS- Mark, I received my set a few weeks ago, great product! It will be a while before it gets installed though . . .
Engman
Nov 3 2005, 05:18 PM
QUOTE |
PS- Mark, I received my set a few weeks ago, great product! It will be a while before it gets installed though . . . |
Thanks - Made enough paper and metal check pieces to make sur that they fit!
QUOTE |
#4, lastly, I'm concerned about keeping rust away long-term for the owner of the car. I was thinking, after long repair, wire brush to bare metal, coat long in weld-thru primer, lay on reinforcement, weld in place, clean welds, POR-15 over the entire reinforced long assy, seam seal at edges, and final coat with some sort of epoxy based paint. Does this sound good to keep rust away long-term? Keep in mind that the entire underbody is also getting POR-15'ed, and that this is a midwestern car and will likely see rain and quite possibly even a little salt in the coming years. |
1. Front and back of the long - use a jack in the center as well to adjust the door gap, Check it after you tack the long on that side in a few places and do so throughout the welding process.
2. Either way will work. Depenfding on the state of the floor - if it is really bad do the long first so the pan will set right.
3. See Type 11969's post.
4. Yep. Good method.
QUOTE |
One more I forgot - would you recommend doing this kit with the engine in or out of the car? The engine is coming out anyway for the hell hole repair and to get cleaned up. |
It*can* be done either way but my preferance on yours would be with engine out.
HTH
Thanks
Mark
iamchappy
Jun 16 2006, 07:50 AM
Mark are these still available.
Chap
Engman
Jun 16 2006, 08:34 AM
Yes - I have a couple in stock.
M
iamchappy
Jun 16 2006, 08:23 PM
Email sent
iamchappy
Jun 22 2006, 09:40 PM
Pay Pal sent ,
thanks Mark.
Chap
Trekkor
Jun 22 2006, 11:27 PM
Yep, good kit.
KT
iamchappy
Jun 26 2006, 05:18 PM
Got mine today, are they coated with weld through primer?
Thanks, Mark
Chap
iamchappy
Jun 26 2006, 05:25 PM
I plan on welding these on, but I was wondering about panel adhesives. They have become so good, the factory and body shops use it all the time.
Engman
Jun 26 2006, 06:45 PM
Yes - weld thru -
No one has done the panel adhesive - yet. I do not recommend it unless you feel you can get both surfaces extemely clean and have done this before.
Thanks
M
dlee6204
Jul 7 2006, 05:26 PM
Email Sent
Brando
Aug 6 2006, 09:16 PM
Mark,
Are you still producing these, or only selling a specific amount?
~B
Engman
Aug 6 2006, 09:37 PM
I just got a new batch in - so yes I have them.
M
neo914-6
Aug 7 2006, 01:27 AM
Mark,
My sponsor Marty (Maltese Falcon) listed them on the detail sheet of my car's SEMA description. He picked few things from my psuedo "dealer" sticker, LOL.
Vehicle Modifications: This is a 21st century remake of a classic Porsche 9146-- the neo9146. Entirely rebuilt (re-made) by hand, featuring classic mid engine roadster engineering, with dynamic styling all done in steel and carbon fibre. Powered by a 250 bhp Audi V6 biturbo 5 valve DOHC engine coupled to a B&M short throw 5 speed gearbox . Big ventillated brakes front and rear, with MSDS spot-disc parking brakes, SMART adjustable sway bars, Engman reinforced chassis kit, full in-car- entertainment (ICE)system, climate control, power windows, power door locks and GT3 Recaro seats. The neo9146 rides on 225/40 ZR 18" front , and 295/35 ZR 18" rear , on 18" Sport Techno wheels. The car still features a front and rear trunk...just as it did 32 years ago !
Engman
Aug 10 2006, 05:40 PM
How coool is that!
But now you have to get there....
Thanks for the plug!
Mark
ferlutt
Sep 3 2006, 02:25 AM
Do you still have this kits for sale?? if so how much and my zip is 92173... how much for shipping?
Thanks!
Engman
Sep 3 2006, 02:37 PM
PM sent...
I have a few in stock. I also have all of my 'other' stuff in stock as well.
Thanks
M
ferlutt
Sep 29 2006, 01:16 AM
QUOTE(ferlutt @ Sep 3 2006, 01:25 AM)
Thanks!
HEy i deleted by mistake the email u sent me, could u tell me one more time how much is it??
Im ready to buy them.
Thx
craig downs
Oct 28 2006, 05:05 PM
Just recieved my kit today. The pieces look great and the shipping was very quick.
Can't wait to install them. Thanks Mark
ptravnic
May 26 2007, 11:45 AM
I hope more of these kits are avail soon...
fat73
Jun 13 2007, 10:07 AM
Any more of these kits available?
Ed aka W9R1
Engman
Jun 13 2007, 04:47 PM
In stock
Mark
AvalonFal
Jun 16 2007, 10:32 AM
I'd be interested in a set also. I will PM you.
Paul
Engman
Jun 28 2007, 10:03 AM
I have several of these available. PM or email me if you are interested.
M
PeeGreen 914
Sep 19 2007, 04:19 PM
So I brought these in with me to the guy who is going to fix my rust issues and weld this kit in my car. He is amazing at what he does. He looked at these kits and was amazed. He was telling me all about how they woud really help a car become more rigid and such. So I would definately suggest adding these to your car.
rufio0205
Oct 8 2007, 07:28 AM
just going to ask this and not care about looking dumb, i need these piece because mine are a bit rusted. are there any other cheaper ones that i could get or is this all that exists?
