Help!
I know I am in over my head, but I need to do all 4 rotors (Zimmermann, which I have) plus all bearings and seals. My right front bearing is making noise. My tech bud says since the rotors are thin, do the right thing. I am, but I need help!
The real deal is, HOW DO I DO ALL THIS WORK?
Questions - I am leaving space between the lines for answers. ANY and ALL answers welcome. I never did this crap before.
1. Are the rear bearings removable without removing the trailing arm?
2. Is there a special rear bearing tool?
3. Is there a rear wheel bearing seal?
4. Do I have to disassemble the rear hubs? If so, is it a good time to install new CV joints? Should I strip and paint the chipped axles? Are there better axle shaft to buy and install?
5. Who makes the best CV joints? Who sells them?
6. Is the front set of bearings pretty straightforward?
7. I have the front rotors, bearings and seals. What else should I buy/replace when I am going this far. The shocks, turbo tie rods, drop arms, and ball joints are all new.
8. Are there any bearing, rotor, caliper, trailing arm threads on here? I am TERRIBLE at search results.
THANKS ALWAYS!
John Lewis
