Hello everybody, does annyone knows how to disassamble the ignition switch of an 911 or 914/6?
I have this:
I want to separate the cylinder.
On the top you can see a little hole, anny ideas for what it is?
Thank you
sechszylinder
May 25 2004, 05:56 AM
hiho michelko,
nice to see someone else from germany ...
i've also tried to disassemble the ignition switch, but i found no way to open it without destroying the case. if you only like to match your keys it's easier to change the door locks.
many greetings from germany / berlin
benno
michelko
May 25 2004, 06:33 AM
Hi Benno, bin mir ziemlich sicher das das DIngens irgendwie auseinandergeht. Bei den verschiedenen 4 Zylinderversionen geht es auch. Man muss nur den Trick kennen!!
Gruss aus Frankenthal (Pfalz)
michelko
May 25 2004, 07:06 AM
Not realy at top:
i marked the hole, its about 1 mm in diameter.
michelko
May 26 2004, 01:27 AM
Hi guys, nobody knows??? Any Ideas?? The fitting key looks like the right one instead of the left (nevertheless i think it is original). Did anybody know if the older keys look like this.
Hope you understand my english i am little out of practice.
michelko
May 26 2004, 01:28 AM
oops forgot the picture
JWest
May 26 2004, 05:52 AM
I have one that is apart, but I did not take it apart. The pin that you pointed to has been drilled out and replaced by a threaded setscrew.
The small key is the style used on '68 and older 911s (and 356s) IIRC.
May 26 2004, 09:54 AM
i'm not really of any help here, but on the early /4 locks, you have a similar hole and you use a pin through the hole to push down on a spring and then the cylinder will just fall out. maybe the /6 (911) lock is similar.
did you try to press down through the hole with a pin and try to pull out the cylinder at the same time? Andy
michelko
May 26 2004, 10:19 AM
Hi there, thank you for your thoughts. I think the drilling out method is the right one. Sir andys idea did not work, the pin moved only half an mm in.
So then i will use drill (looks like)
