EJP914
May 25 2011, 06:55 PM
I have quite a bit of fluid running out of the transaxle at the seals at the inner CV joints and I guessing the seals are shot. Probably original.
Can you remove only the 4 bolts and swing the axles shaft and CV joint out the way to get to the flange and then the seals? I seem to remember there is some slop on the outer CV joint that will allow the axle shaft to move around a bit once the inner bolts are removed.
I am hoping I don't have to remove the heat exchangers and the big castle nut.
Can I get at these seals without removing the HE's and entire half shaft.
Thanks for the advice.
tradisrad
May 25 2011, 07:26 PM
yes, the side shaft seals can be replaced in the car. no need to remove exchangers just unbolt the CV joint swing it out of the way and remove the flange. I did one in the car earlier this year and it was fairly easy. use new washers on the CVs.
Hammy
May 25 2011, 08:48 PM
CV joint grease or tranny fluid ?
EJP914
May 25 2011, 09:19 PM
The leak is definitely tranny fluid. I can see where it is coming out at the side seal and running down the side of the transaxle case.
r_towle
May 25 2011, 09:33 PM
easy fix.
Unbolt axle and move it.
Large bolt removes the flange.
Seal is simple.
Rich
Haudiosolutions
May 26 2011, 06:06 AM
It is an easy fix. The hardest part was pulling the old seal out.
914itis
Oct 27 2013, 07:45 PM
Reviving an old thread.
I can't seem to find the axle seal on the bird's site any pointers
SLITS
Oct 27 2013, 09:42 PM
914itis
Oct 27 2013, 09:52 PM
Thanks, just ordered a set.
