Hey guys I really appreciate the thoughts back from you guys. Firstly, I have no previous motor exp as the car came with most of its FI in pieces and a low compression hodgepopge of a 1.7 out of an earlier car with bus heads on it. So my chances of getting that to run with out serious money was impossible. although being a previous type 1, type 2, owner I almost yearned to see what a lightweight aircooled motor was like in this car I had been down the aircooled road... infact still have aircooled bikes. SO that being said I sadly have never driven a stock 914, I'm sure Jon Bovey(peegreen) will make sure I know the difference some day. Now the motor in it right now The Ej22 is something else, having played with semi hot rodded type 1 motors I know that a vw motor can get moving, but this motor combo seems to be the cheapy elite formula for building a car that won't instantly destroy the stock drivetrain. Running very open exhaust and cold air styled intake with stock legacy ecu the fueling could be a thousand times better (I need a megasquirt badly, anyone got a half started megasquirt kit that never finished?) Granted closed loop cruizing is pleasant. A person with a well tuned butt dyno can feel the slightly off fueling in quick accelerator action to full throttle. all this aside I LOVE THIS CAR. The motor has plenty of passing power at freeway speeds, plenty of low end torque lugging around at 1800-2000 rpm.
Now I originally wanted to go down the road of engine bay cooling because I loved the versatility of having a car with a frunk. so that is why i have been stubborn and screwed around with this setup and didn't go to more tried idea. I love the thought of two littler radiators like a 996 or cayman. I actually thought slightly of it when looking at a spare crashed on ducati 996 radiator in my garage. If I could find some small radiators that would do the trick i would give it a shot. I don't really wan't to make something custom as its all experimental and may not work and I don't have a budget so I have to work on stuff out of the garage to make 914 money. But this may be the evolution of my design to have two radiator sealed off to the sides of the motor sitting between the intake runner and ends of the engine bay. with a shroud that goes inbetween the two radiators to hide the motor.
Andyrew Dude good luck. I think with some trick fiber glass and a big radiator that fits just right, and some math as to the size of entrance to the radiator vs the exit of airflow and it could be done.
Now the switch fan polarity would be cool in order to change the flow for different speeds. What would be even cooler would be to have a logic circuit hooked up to a speed sensor that would do it for you. I have no idea how to build said circuit .... but a thought.
I think currently I will play around with changing the fan around. Building some fiber glass shrouding in the engine bay under the radiator to influence more air up thru the bottom and out thru the radiator. also there are other things I should do to increase ability to cool. I was running straight distilled water no coolant. I'm sure that most coolants help increase the cooling transference capabilities of water. and to get more crazy there is always water wetter. Now I will admit I worry about spirited driving in the mountains which is by the way all too much fun, granted i noticed if i was in a more agressive driving mode going up the mountain it seemed to take longer to heat up, higher engine speed = higher water pump speed + more airflow. It was really putting up the hill in 5th behind motor homes that made it wan't to boil. Anyways thanks for chipping in.
I'll keep you guys posted. sorry about the novel of a reply here... just have a lot on my mind I guess.
