QUOTE(Mueller @ Apr 25 2003, 01:30 PM)
I have seen conversions with the key on the "correct" side.
yes, but would you also switch to the early 911 (actually probably a 912) steering-column ? plus, as brad pointed out, the ignition switch in a original /6 is at a slight angle, on a /4 conversion it would not be. as you can see in the pic, the switch is in an angle ...
anyways, i think it's a original /6 which makes it even more unlikeley someone would cut it up to put a boxster engine in it ...
Andy
