QUOTE(watsonrx13 @ Jun 15 2004, 01:54 PM)
Andy, please tell us how (you 914 guru god).
We will need detailed descriptions and with very detailed (regular and close up) pics.
i can take pics later ...
here's the quick rundown:
1) you can either buy a way overpriced 914/6 washer pump OR
you go to your local porsche salvage yard and get a washer pump from a '70s 911 (which looks strikingly similar to the 914/6 pump
2) then, you mount it in the stock (914/6) location which is under the washer bottle.
3) rip out all the washer hose that goes from the bottle to the steering column (careful, could still have water in it),
but keep it, we'll need it later.
4) remove the 2nd hose from the steering colum and fiddle it back into the cowl area through the front firewall.
take the hose and connect it to the outlet of the pump. (you may wish to trim it, it's too long).
5) remove the hose from the spare tires and fiddle it through the firewall, throw it into the trash.
6) take the hose from 3) and put one side back on the bottom of the bottle (special connector, don't brake it!), then cut the hose to length and connect to the input of the pump.
7) take off the black bottle cap and drill a small hole into it, next to the valve stem (hole size about the dia. of the washer hose).
this is needed because the cap has a pressure valve in it that won't allow air to get into the bottle. you need to bypass this, otherwise the pump will not be able to get much water out of the bottle.
8) 2 options for the wiring:
8a) run 2 wires inside and mount a separate switch (push button style) either in the dash or the center console, and hook it up to 12V (through a fuse of your choice)
8b) if you have the intermittend wiper relay harness, you can also run the pump off that, just extend the brown/black wire (trigger from steering column) and use it as the 12V feed for the pump.
this way, every time you pull the wiper lever towards you, you get the 4 run intermittend + fresh water!
pics will follow,
Andy
