QUOTE(Jeffs9146 @ Aug 9 2011, 06:08 PM)
If you cant read it the blk/purple wire is the one that comes out the top and goes to V5 which is the RPM limiter switch on a 1983 911sc 3.0L!
I am guessing that the RPM limiter is set to defalt ground or is not in the motor parts that I have installed and thats why it is doing this?
Jeff,
The V5 on the diagram actually means the current track continues on diagram page V, track 5 which is the Tachometer. Both the blk/violet wire from Term TD on the CD unit and the white/red wire from term 3 on the RPM limiter go to the TD terminal on the tach. The RPM limiter shuts down the fuel pump when the RPM is too high, the white/red wire is just the tach signal to the limiter.
The blk/violet wire to the TD terminal on the CD unit should be correct, I would be looking at the connection to the tach or the tach itself. Make sure it is connected to the TD terminal and nothing else is connected with it unless you have the RPM limiter wired in.
Glad to hear you got it running, been out of town so I'm just catching up on your progress. Sorry about the oil cooler, that sucks. Have you looked for a source of oil leaking on top of the cooler?.
Jim
