a few tips about installation:
the whole harness must be installed from inside the cabin!
everything that goes to the back of the car, rear trunk, engine comp, center tunnel has to be fiddled in from the
FRONT of the center tunnel backwards!
meaning, the taillight wires first, then string the whole back end through.
NOTE: in the front part of the center tunnel, the harness routing is *different* for early/late cars!
don't miss that first hoop or you won't be able to fit the mount for the floor board!
it's a lot easier to fiddle the big connectors through tight holes FIRST, even if they're not the first thing in the harness, if you feed the smaller wires first, the bigger connectors won't fit anymore.
this will take some practice
yes, all the engine and rear trunk stuff fits through the rear firewall hole, even the big rubber boot!
trust me, you can do it!
btw. it *REALLY* helps having a second person sitting in the engine comp while you feed the stuff through!
once the rear is in place, feed the front part through the front firewall (left from the steering wheel).
same here, feed bigger connectors first!
Andy
