Finally finished the longest strut conversion project in history, and I'm selling the original parts.
First set: 5 lug adapters. After my car was off the road in 2002-2004, I put these on the front to get back to driving. They worked fine for me, and only have about 5000 miles on them. These space the wheels out 1". I used them with flares and 15x7 Fuchs and the clearance was about perfect.
I'm including the attachment lug bolts, AND a socket that I ground down to fit the counterbore to torque the bolts.
These could be used either front or back.
Asking price: $50 for both. This doesn't include shipping. I can get this in a flat rate box to US only for an additional $14.95.
Click to view attachmentClick to view attachment
Second set: 914/4 front rotors drilled and tapped for 5 lug. I got these new from AA when I did a brake job back in the '90's. I ran them 4 lug, but my plan was to do a 5 lug conversion later. When I finally did the conversion, I had flared the car, and wanted some spacers in there, so I used the adapters (above) to give me 5 lugs but with 1" spacer. These front rotors are in great shape. They have about 12,000 miles on them but there isn't even a ridge around the circumference of the rotor. Take a look at the photo.
Included are the front rotors, 10 screw-in studs (never used), bearings (untouched in the hub), dust caps, spindle lock nuts, tab washers, CALIPERS WITH PADS, and dust shields. (you'll need to use your old lock bolts on the spindle lock nuts; I needed them for my new set up.) If it's not in the photo, it isn't included. All parts from an original '76
These could bolt on to your car in a couple of hours, and give you used (but excellent) front brakes along with a front 5 lug setup, ready to go. This is a great package even if you're just looking to do a front brake job. You could even use these bearings and old grease as is, but you really should repack them and replace the grease seals, duh.
Asking price: $100, NOT including shipping. I can fit everything in three flat rate boxes for $14.95 each, or you pay actual on any other means. Pick up encouraged!
Both sets ($150 plus shipping) would give you a reasonable 5 lug conversion at all four corners- drilled hubs at the front, and adapters in the rear.
