DNHunt
Jun 29 2004, 11:18 PM
Gerry and I took on the connecting rods tonight. Lotsa fun, kind of a big model. We measured the bearing to journal clearance and all were .0015" and rod side clearance was .012 to .014 on the 4 rods.
Here's Gerry torquing down the rod bolts on #2
DNHunt
Jun 29 2004, 11:26 PM
Here's Plastigauge on the journal. Very fun. It's a thin thread of wax that spreads out when it gets compressed. You get the thickness of the space for oil between the parts by measuring the width of the thread after the parts were torqued.
Jake Raby
Jun 30 2004, 01:01 AM
Looks like you are doing it right....
The plastigage and other tolerances were already measured for you though....
ablose58
Jun 30 2004, 01:06 AM
NICE , Dave
Can't wait to see it all together
Rusty
Jun 30 2004, 01:45 AM
Very meticulous... clean and check everything, even if the parts are fresh from the machine shop or right out of the pacakge.
You're going to have a great motor.
-Rusty
DNHunt
Jun 30 2004, 06:34 AM
Jake
I was pretty sure you did all that but checking things is in my nature. One of the sayings we heard in dental school was "We can teach a monkey to do this is six months. You ought to learn as fast as a monkey so what are we going to do with the rest of the time? We'd say "Teach us to think like a dentist" That meant check everything including stuff that was just done. Our advisor was an old Marine.
Anyway, Gerry got to do it and maybe he'll remember how careful we were.
Dave
newdeal2
Jun 30 2004, 06:59 AM
I see an extension on the tourque wrench...is that OK?
DNHunt
Jun 30 2004, 07:06 AM
Yep, but not the way he's holding the wrench. I wondered if someone would notice. It's a posed picture.
Dave
newdeal2
Jun 30 2004, 07:14 AM
I'm a stickler for detail and about to get into the same mode of operation on my first rebuild. I received the AA flat top pistons and for the money they look decent. The pistons are nicely done, wrist pins fit with ease and the cylinder walls have a nice fine cross hatch.
I will post pictures later.
Peter
74 2 liter
Jake Raby
Jun 30 2004, 07:34 AM
Double checking is good... ALWAYS.. I design and engineer the kits so none of the checking is needed from guys that don't have tools or plastigage.
With the kits I mock everything up, ensure its going to clear, set the tolerances and get it 100% ready to be cleaned and then assembled... Thats why the kit is not just a box of parts- the work takes hours and hours.
Using an extension on the torque wrench is fine, adding an angle to the drive (like a crows foot) is not fine and requires a correction in the torque setting to be made.
DNHunt
Jun 30 2004, 09:34 PM
Tonight wasn't as fun as last night. I spent the evening cleaning some of the mating surfaces. For the record the kid disappeared fast when the word cleaning came up. So it was me, carb cleaner a plastic scaper and my thumbnail. Not sure what they used the lastime they put this together but Berryman's carb cleaner softened it pretty well.
I'm waiting on hardware now. It's probably a good thing cause it gives me time to clean then clean some more.
Dave
DNHunt
Jun 30 2004, 09:38 PM
Taco plate area
Mueller
Jun 30 2004, 09:44 PM
...I think we spent 2 solid days debating the +/-'s of that statement in A&P school
Me, same thought as you in the real world.
look'n good Dave
Jake Raby
Jun 30 2004, 09:48 PM
Even the "anal retentive" Naval Turbine instructors told us that rigid extensions were fine as long as torue was less than what would make the extension become torsional.....
The fun part is that most people don't know that torquing a bolt head instead of the nut requires 10% more torque to achieve the same tesnion on the fastener as tightening the nut.
Hell, these engines are so forgiving that they can be assembled with apair of pliers and nothing else..... I have done it
brp914
Jun 30 2004, 10:08 PM
I didn't see it mentioned here, so I will:
1. the 3 digit # stamped on the rod must be matched with the cap of the same #, and assembled on the crank with both #'s side by side.
2. All the rods should be mounted on the crank such that 3 digit #'s face up as viewed from above the engine. In other words, as if looking down on the engine installed in the car.
Jake Raby
Jul 1 2004, 06:54 AM
Brp,
My rods have zero offset... They can be installed anyway that the installer see's fit.
My rule of thumb is that "bearing tangs go toward the cam" and thats the way I install them... When I clearance the rods the numbers disappear in most cases.
DNHunt
Jul 1 2004, 07:31 AM
True no numbers but, there is plenty of red paint or marker on 1 side of the rod and blue on the other. They even marked the head of the rod bolts. I suppose you could mess up but, I think it would be difficult. The rods are also marked with an engraved # corresponding to the piston and wrist pin that they are balanced with. It's probably not quite idiot proof but darn near.
Dave
Jake Raby
Jul 1 2004, 07:33 AM
There is no substiute for Indexed parts!
Joe Ricard
Jul 2 2004, 02:33 PM
How come # 2 connecting rod is the first one from the cam gear end of the engine? or furthest from the flywheel? Those silly germans
Jake Raby
Jul 2 2004, 04:46 PM
It doesn't matter where they go... We number the parts for our working purposes during balancing. Since all rods are clearanced and balanced end to end there are no worries, there are no offsets on rods or pistons so in reality you could install any part in any hole and it would be fine. #2 is the furthest from the flywheel, and #4 is one notch back from it... #3 is closest to the flywheel and #1 is one notch forward of it.
The only part of dave's engine that would matter for index is the custom pistons, sincethey have valve reliefs and they must be indexed to align with the intake and exhaust valves...
Joe Ricard
Jul 2 2004, 07:27 PM
Damn, thats cool. who woulda thunk that them Engineers did that on purpose just to make seem difficult.
doesn't even follow logic of "port/stbd" odd or even. No wonder adjusting valves always kicks my ass.
