some good news for a change ...
i won't be at the AX on Saturday, so trekkor doesn't have to worry about me spanking his a$$
no, that's not the good news, good news is that after dropping the engine and taking the tranny off we (or should i say bill) discovered that the quarts of oil on top of my engine did NOT come from a cracked case but rather from a shot seal behind the flywheel.
i lost about 2 quarts of oil on a 40 miles run (just cruising on the idle jets).
i don't have the little plastic covers for the holes behind the flywheel, so all that oil flung up and sat on top of my engine.
this should be a easy fix.
now back to the weird. with spark-plugs removed, cap off rotor and no flywheel/clutch/tranny attached, shouldn't it be fairly easy to turn the engine at the fan?
yes, i do have double-springs on the valves, but i can barely turn the engine over by hand.
in fact, bill had to hold it down while i was pulling, otherwise i would have pulled it off the table!
also, every half or so revolution, there's a wierd noise (clunk) coming from the back, pass. side of the motor. (sounds like from inside).
valves were adjusted and all looks thight there, we had the valve covers off but could not see anything out of the ordinary. any ideas?
i'll be back and take some pics tomorrow morning,
Andy
