what a adventure!
first, let me thank brad for all the hours of work and rich for the parts and stuff, couldn't have done it without you!
ok, so, what's the big deal? you buy a new motor, drop the old one, put the new one in, voila!
yeah right ...
what should have taken 4 hours max. turned into a 2 days(!) late night work-session, 12+ hours total. in fact, i just got home 10 minutes ago.
THE GOOD
old engine went out easy.
the new engine runs (somewhat).
THE BAD & THE UGLY
we bolt up the new engine to the tranny and wiggle it into the car, this went pretty much like planned, then we take the first look at it from above ...
hmmm, how is that carb-linkage supposed to work?
shit! it's backwards! yupp, carbs were mounted flipped (wonder if the builder is a VW-Bug guy).
so we take the carbs off, hmmm, bolts are only hand-tight! that's not good ...
flip 'em and back on, now to the throttle cable.
SNAP ...
shit again, thread just snapped off. oh well, guess i always wanted a terry-cable anyways.
put the coil on, let's check the dizzy. ooops, cap is loose ...
it rotates even when clipped down. wtf??? we look at it, hmmm, groove and tab are there, try to fit it again, ohhh, cap is wrong size! it moves around on top of the dizzy. nothing a piece of duct-tape can't fix.
next is the oil, motor got a tuna-can so we need some more oil than usual.
all seems fine, no leaks yet.
ok, let's fire her up. vroom, starts right up, yeah!
but wait, why is the alternator light on???? we grab the multimeter.
yupp, alternator is TOAST. of course the engine is now IN the car. grrrrr
this is where we decided to call it a night last night (about 1pm).
i crash at brads house and off to work this morning (not in my car, mind you), then back to HPH around 4:30 pm today to finish the install ...
so, i get there, check under the car first. puddle of oil!!!
looks like it's coming from the taco-plate ...
car on the lift, yupp, oil-temp sender is leaking. brad jokes "maybe they just hand-tighten that one too". and sure enough, it turns by hand.
right about now i'm getting a bit concerned. i hope the internals of the engine are not just hand-tight either.
i get a new alternator from rich ($$$) and start taking the old one out.
if you have ever done that while the engine is still in the car, you know how i feel right about now. new alternator is in, then adjusting the clutch and throttle.
i quickly make a "puke-bottle" out of a old oil-can and hook it up to the case-vent to collect the oil-vapors. ready for a test drive!
get the car in gear, hmmmm, what's that crunch noise coming from the clutch ???
shit, i didn't check the clutch/pressure plate, flywheel for correct torque!
if there is a god out there ... please don't tell me those are just hand-tight either
pull out of HPH, car idles fine. i'll try to go smooth. bog, almost dies. once, twice, more gas, now it drives. wtf?
whenever i go from idle/just a little bit gas to more, there's a complete DEAD spot, the car almost dies. no power. zero. zilch. if i floor the gas, it starts moving again. i have heard about carbs having a flat spot when coming off the idle jets but not like this. this is like the ignition cutting out for 2 seconds and then hitting again. makes for "interesting" driving.
by now, it's 10pm and we're ready to call it a night again.
i pack up my balls and decide to try the drive home (~45 miles, mostly freeway).
as long as i keep it just rolling on the idle jets (around 3000 rpm in 5th) the car runs smooth. as soon as i give a bit more gas, it almost dies, no power, even backfire.
so i get home and as i try to park the car, the clutch noise is now REALLY loud.
a metal "crunch" of sorts, like something is loose ...
don't know exactly where it comes from, will check tomorrow in the light, but it does NOT seem to come from the vent/filler/puke bottle.
let's have a last look into the carbs ...
i look down the venturi and move the cross-bar.
well, what do we have here! all four carbs squirt completely different amounts of fuel and at different times too ...
on 2 (cylinder 2 and 4) the mains seem to come on fairly early with decent amount of fuel, almost sync.
cylinder 1 and 3 are completely off, way less fuel than the other two and the mains come on much later as well.
oh well, i guess by now i'm not surprised anymore. looks like those carbs were not setup or adjusted either. i wonder if all the bolts are tight ...
moral ????
if you haven't build it yourself DON'T EXPECT ANYTHING TO BE DONE RIGHT.
double check every fucking nut and bolt for correct torque etc.
i really hope this is not the beginning of a motor-nightmare ...
i'm tired now. i'll have a beer. or two ...
later guys,
Andy
