Here is a pretty good basic list borrowed from ShoptalkForums.com.
"CIS-The checklist for a CIS basic system of stuff you need is the airbox/airflow meter/fuel distributor/boot assembly, injectors/injector lines, cold start injector and ambient air temp. sensor/electrical connector, warm-up regulator(WUR) and electrical connector, throttle body, fuel pump and accumulator(canister looking thingy), auxiliary air valve/electrical connector, the fuel pump relay, the banjo lines to and from the fuel distributor, and at least cut some of the hard fuel end off that threads into the banjo lines or take the whole hard line with you. This last part, there are options about mating AN fittings onto these ends(push on line and hose clamps are not an option though, this is high pressure stuff-->80psi). There is a specialized tool for pulling the injectors to simplify things, a long screwdriver and penetrating oil helps too. "
http://www.shoptalkforums.com/viewtopic.ph...65&t=114309
