I sort of killed this one by my own hand, so I don't have much concern about there being some other electrical issue that will burn up a replacement. My car has no engine tray and the relay has been bouncing around inside the engine compartment ever since I bought the car. I knew it was a problem but fixing it never made its way up the priority list. The plastic enclosure was eventually worn through until the PCB was worn away and the insides of the relay are also now corroded.
Whatever I replace it with (new or used) will be mounted securely out of the way.
Thanks,
Mike
QUOTE(Jaymann @ Sep 20 2011, 10:28 AM)
QUOTE(PDXMike @ Sep 18 2011, 09:08 AM)
I need a dual relay for a 75 1.8L L-Jet. The part numbers on my dead one are 071 906 059A (VW) and 0 332 514 125 (Bosch). This is the newer version of this part, but I believe the old metal-can one would work too.
Thanks,
Mike
F.Y.I. The new relays have plastic covers,that must be modified to fitt.Also, I think there may be a bosh part # typo in there parts catalog.Make sure you know how many pins your relay has.I would suggest you go with a nos relay with your origianal part # they are tested easy,and they hold up very well.If you get stuck,I will sell you a used one, in good working order.For 40.00 bucks Jason from PA
